February 11, 2022 at 2:45 pm
Don.Rainwater
SubscriberI have Ansys 2021 R1 installed on a Linux server, but it won’t run. Previous versions did not have a problem, and the installer for this version completed successfully. Any ideas? See below:
% /usr/local/ansys_inc/v211/Framework/bin/Linux64/runwb2Â
Unhandled exception caught :
System.DllNotFoundException: Ans.QT.dll
at Ansys.UI.Toolkit.QT.Application.SetPluginDirectory () [0x000f2] in
:0Â at Ansys.UI.Toolkit.QT.Application..ctor () [0x00006] in
:0Â at Ansys.UI.Toolkit.QT.UIFactory.newApplication () [0x00000] in
:0Â at Ansys.UI.Toolkit.UIFactory.newApplication () [0x0000f] in <10126af23bce40849ad4266af89c19d0>:0Â
at Ansys.UI.Toolkit.Application.InstantiateIApplication () [0x00000] in <10126af23bce40849ad4266af89c19d0>:0Â
at Ansys.UI.Toolkit.Application..cctor () [0x0000a] in <10126af23bce40849ad4266af89c19d0>:0Â
--- System.TypeInitializationException: The type initializer for 'Ansys.UI.Toolkit.Application' threw an exception.
at Ansys.UI.UIManager..ctor () [0x00060] in
:0Â at Ansys.UI.UIManager.get_Instance () [0x00029] in
:0Â at Ans.Program.Runtime.InitializeSplashScreen () [0x00060] in
:0Â at Ans.Program.Runtime.Initialize (Ans.Program.RuntimeSettings settings) [0x00237] in
:0Â at Ans.Program.ExecutableBase.Run (Ans.Program.CommandLineParse parser) [0x0000d] in
:0Â at Ans.Program.ExecutableBase.DoMain (System.String[] args) [0x000cf] in
:0 February 14, 2022 at 4:18 pmGeorge Karnos
Ansys EmployeeWhich release and version of Linux are you running on?
Also, check the prerequisites in the installation guide for the version you are installing.
Does an install.err exist under /ansys_inc
February 15, 2022 at 5:44 pmDon.Rainwater
SubscriberIt's installed on a file server running OpenSUSE Leap 15.2 in /usr/local, which is exported via NFS to various clients running CentOS 7.
No install.err in /ansys_inc
I don't think I've seen an installation guide. I just ran the INSTALL script as I've done for previous versions, and it completed successfully.
February 18, 2022 at 12:27 amGeorge Karnos
Ansys EmployeeI apologize for the delay.
The issue is most likely caused by missing OS library named libpng12 in CentOS.
Viewing 3 reply threads- The topic ‘Problem with Ansys 211 installation’ is closed to new replies.
4502
1494
1376
1209
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
