June 29, 2023 at 11:45 amdmitry.zhukSubscriber
I'm using the procedure from that page: https://simutechgroup.com/post-processing-apdl-models-inside-ansys-workbench/
It worked fine before but when tried to open 200 Gb .rst file it gives an error: An error occurred while copying result file to the solver files directory.
I don't have additional 200 Gb on my hard drive to get file copied and I don't really see the point of copying. I tried to move .rst file to ..\dp0\SYS-1\MECH before opening it in WB but error presists.Any help is appreciated
June 30, 2023 at 6:43 amAniketForum Moderator
This error most likely is about the space while reading the rst file, you may want to open a new SR with us if possible. An alternative approach to this one would be reading rst file using opensource pyAnsys products. One example can be found here:
Basic DPF-Core Usage with PyMAPDL — PyMAPDL (pyansys.com)Â
-Aniket
- The topic ‘Post-processing APDL .rst file in WB’ is closed to new replies.
- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- How to apply Compression-only Support?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
1191
513
488
225
209
