May 13, 2022 at 6:10 pmangelo_97Subscriber
Hello everyone, I'm simulating a microfluidic spiral with a rectangular cross section. I used a UDF to include the wall and the shear force but when I simulate i see theta the particles stay at the outer wall and not at the inner as should be. I see the dean vortex but i don not why they are so small and are not able to push the particle towards di inner Wall. Someone have some any ideas?
Thanks in advance
May 16, 2022 at 9:02 amRobForum ModeratorPlease post some images. I assume you set up the fluid & particle materials correctly? How big are the particles relative to the zone & mesh?
Viewing 1 reply thread- The topic ‘Particles focusing distance’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Fluent fails with Intel MPI protocol on 2 nodes
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script error Code: 800a000d
- Encountering Error in Heterogeneous Surface Reaction
Top Contributors-
1191
513
488
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
