para.h in UDF
    • Sai Manikanta Kaja
      HI, I am trying to write a matrix to a file using UDF,  teh below is loop is used in customisation manual
      compute_node_loop_not_zero(i)
      in the example, It says, we can know more about it by refering to para.h
      I am unable to rech to documentation of the same. Please help me how to read about the same.
      Thank you
    • Nikhil N
      I think this is referring to the 'para.h' file in the Fluent's directory.
      May I know how can I access the same ?
    • Nikhil N
      You can find this file within the directory of your locally installed Ansys products, specifically Fluent, on your system. You can use the search in the File Explorer.
  • The topic ‘para.h in UDF’ is closed to new replies.
