October 16, 2023 at 3:33 pmMD ARAFAT HOSSAINSubscriber
Dear Altruist!
I want to calculate the shear force of a polymer nanocomposite material using Fluid Flow (Polyflow). My material is non-Newtonian. But there is no option for non-Newtonian calculation in CFD polyflow.
Is there any way I can calculate the non-Newtonian fluid flow problem?ÂThanks
Arafat
October 17, 2023 at 2:26 pmPrashanthAnsys Employee
Hello, polyflow is intended mainly to cater for non-Newtonian flows, with strong nonlinearities. we supply any of the available shear-rate dependent viscosity laws to model non-Newtonian flows in polyflow.
October 18, 2023 at 8:25 pmMD ARAFAT HOSSAINSubscriber
Thank you. I appreciate your help.
- The topic ‘Non-Newtonian Fluid Flow problem’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Cyclone (Stairmand) simulation using RSM
- Fluent fails with Intel MPI protocol on 2 nodes
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
543
523
225
209
