June 17, 2025 at 4:23 pm
emmanuel.taiwo
Subscriberfor SPG simulation is it not possible to set node to surface contact for coupled structural thermal anaylsis. the solver returns, that i have to set surface to surface contact in this case.Â
this is my contact set up, but when i change to surface to surface its takes off this error. but that is not the standard i know for node to surface contact set up like SPG.
if anyone could guide.Â
June 17, 2025 at 4:49 pm
Nanda
Ansys EmployeeHello Emmanuel,
Ansys employees are not supposed to open any links posted in the forum. Could you please paste the screenshots directly?
Nanda.
Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
Have a look at our public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
June 17, 2025 at 4:54 pm
emmanuel.taiwo
Subscriberi pasted them as a screenshot before, but see below what is in the image.Â
first image: Â *** Warning 20319 (STR+319)
   redundant prescribed motion constraint.
   node or part id of rigid body = 1
   birth time reset to 1.0e+28second image
*CONTACT_AUTOMATIC_NODES_TO_SURFACE_THERMAL_ID
$#   cid                                 title
   1252ETcontSPG
$#  surfa   surfb  surfatyp  surfbtyp  saboxid  sbboxid    sapr    sbpr
    11     12     4     0     0     0     0     0
$#    fs     fd     dc     vc    vdc   penchk     bt     dt
    0.3    0.3    0.0    0.0    0.0     0    0.01.00000E20
$#   sfsa    sfsb    sast    sbst   sfsat   sfsbt    fsf    vsf
    1.0    1.0    0.0    0.0    1.0    1.0    1.0    1.0
$#    k    frad     h0    lmin    lmax   ftosa   bc_flg    algo
  60000.0    0.1  60000.01.00000E-6   0.001    0.5     1     0
$#   soft   sofscl   lcidab   maxpar   sbopt   depth   bsort   frcfrq
     0    0.1     0   1.025     2     2     0     1 -
June 17, 2025 at 5:20 pm
Ram Gopisetti
Ansys EmployeeHi,Â
For the warning, see if you have applied multiple definitions of the same degree of freedom of nodes corresponding to the rigid part.Â
I am not sure of the question here, but usually, temperature due to mechanical work is supported in SPG.Â
However, the heat transfer between SPG/FEM through contact is not possible.
Cheers, RamÂ
June 17, 2025 at 6:30 pm
emmanuel.taiwo
SubscriberHi Ram,Â
Thanks for your reply, but i do not understand what you mean by the first line of your response.
yeah am focus on temperature due to mechanical work but dose the contact has to be surface to surface or its has to be node to surface.Â
I have created a name selection and also nodal selection of the SPG body, and in my contact definition i have scoped the master as the FEM surface and scoped the slave to the Nodes of the SPG body. this process works when i am focusing on structural analysis.Â
when i switch to thermal coupled analysis - its return error asking me to change to surface to surface contact for thermal simulation.Â
I hope you understand now,Â
Regards,Â
Emmanuel
3622
1313
1142
1068
1008
