August 19, 2024 at 9:39 am
August 20, 2024 at 4:21 pm
igandiko
Ansys EmployeeNCPU is used for SMP and Hybrid solvers. The correct command to run MPP LS-DYNA is,
/path/mpirun -np 128 /path/ls-dyna.exe i= input.k
If 128 MPI ranks are on different hosts, you may need a file with a list of hosts. Please see here for more information (https://ftp.lstc.com/anonymous/outgoing/support/FAQ/mpp.getting_started).
August 21, 2024 at 1:19 pm
Atish Gawale
SubscriberHi,
I am running fluid analysis using CESE solver.
I am able to use higher processor now. I ran with 16 processors and I get following error.
With MPP_D and 1 processor there is no error. with higher processors I get following error.
mes0000
No elements with calculated timesteps1 t 0.0000E+00 dt 2.22E-09 flush i/o buffers 08/21/24 13:46:171 t 0.0000E+00 dt 2.22E-09 write d3plot file 08/21/24 13:46:17*** Error 100116 (CESE+116) (processor # 0)20959704 errors detected in CESE solver during step = 1*** Error 100117 (CESE+117) (processor # 0)1 of these CESE solver errors detected on processor # 0*** Error 100118 (CESE+118) (processor # 0)Errors detected in CESE solver integration step.Please check each processor's message file for details.When error termination was triggered, this processor waspast the output routinesmes0001 - to mes 0015 i got following error.No elements with calculated timesteps
*** Error 150209 (CHEM+209)
Chemistry EOS nonlinear temperature solver failed to converge.
Error code = 50 Last iterate temperature = NaNDo I need to include any control cards for MPP (*CONTROL_MPP_XXXXX)?Regards,
Atish-
July 10, 2025 at 9:44 am
Jacques
SubscriberHi Atish Gawale,
Have you found the reason for that, I get the same problem with you.
*** Error 100116 (CESE+116) (processor # 0)29 errors detected in CESE solver during step = 36*** Error 100118 (CESE+118) (processor # 0)Errors detected in CESE solver integration step.Regards,
Jacques
July 16, 2025 at 2:36 pm
Atish Gawale
SubscriberThis error is very common in *CESE fluid solver with *CHEMISTRY and related to non-physical model setup or non-convergence as well.
Please check if you have included all necessary keywords in your model.
Atish
6410
