August 12, 2024 at 6:54 pmNawafMSubscriber
Dears,
I faced a problem while using fluent meshing. I'm running an external Aerodynamics case.
I named general named_selections of the CAD around 8 name_selections, the mesh was generated successfully and took around 5 min for surface mesh and 7 min for volume mesh. Â
When I further divide the same named selections and generate a total of 25 name_selections of the CAD the mesh is taking a lot of time to be generated.
 Does anyone know why is this happening?
August 12, 2024 at 7:57 pmFedericoAnsys Employee
Time for mesh generation should not be affected by the number of named selections in your model.Â
Do you end up with the same number of cells in both mesh?
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
599
591
565
366
