August 19, 2020 at 8:35 amShortySubscriber
Hello!
Is it possible to create a:
Report Definitions --> New --> Force Report --> Moment Report
which generates an .out -File in which i can see separately Pressure-Moments and Viscouse-Moments? Not
just the total moment?
Similar to what I get when I go to:
Results --> Reports --> Forces --> Moments
August 20, 2020 at 6:44 amKeyur KanadeAnsys EmployeeYou can use Write option to write .frp file. nIf you want to monitor it over time, you may want to create a report definition. nPlease see help manual for report definition details. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnAugust 20, 2020 at 8:42 amAmine Ben Hadj AliAnsys EmployeeWith next versions this will be directly available.nNow the workaround as suggested by my colleague is to write that output into a file.nViewing 2 reply threads- The topic ‘Moment report definition with seperatd Pressure-/viscous-Moments’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
Top Contributors-
1351
594
591
540
366
