April 27, 2025 at 11:53 pm
leila
SubscriberHello,
I want to model a composite in 2D plane stress using ANSYS Mechanical. I have already defined the material properties for each composite layer. How can I define the fiber orientation, considering that it is a 2D model? Specifically, the fibers are oriented at 45 degrees relative to the XY plane.
Is this possible in ANSYS?
Thank you for your help!
April 28, 2025 at 1:46 pm
Govindan Nagappan
Ansys EmployeeSee if you can use the "element orientation" in Mechanical to rotate/change the element coordinate system.Â
Material properties are applied in the Element coordinate system
April 28, 2025 at 2:41 pm
leila
SubscriberThank you for your reply. Unfortunately, "element orientation" is disabled for 2D analyses in ANSYS.
Do you have any suggestions on how I can define the fiber orientation of the composite as out-of-plane (e.g., 45°), even though the surface lies in the XY plane?Looking forward to your insights
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
- PlugIn Error: Failed to import assembly from SpaceClaim. The object is deleted.
2999
970
857
761
599
