October 31, 2021 at 1:18 pmEzzadSubscriberNovember 1, 2021 at 12:40 pmKarthik RemellaAdministratorHello Unfortunately, we do not have any model or mesh files that we can readily share with you on the forum. Perhaps, other members on the forum may be able to help you with this request.
The link in the screenshot is pointing you to the Fluent Theory Guide that explains the theory behind the Autoignition models. I'm pasting the link here.
10.2. Autoignition Models (ansys.com)
I'm not an expert in this area. But, there is an old tutorial on WorkBench that, perhaps, may help you get started. You should be able to download the files under Fluent 19.2 -> Fluent WorkBench Tutorial Files & PDF.
Chapter 6: Solving a Gasoline Direct Injection Engine Simulation (ansys.com)
Karthik
Viewing 1 reply thread- The topic ‘Model Autoignition in Fluent’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Cyclone (Stairmand) simulation using RSM
- Fluent fails with Intel MPI protocol on 2 nodes
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
Top Contributors-
1216
543
523
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
