November 11, 2024 at 4:10 pm
muhammadagussriharto
SubscriberHi guys, I found an problem when I generate mesh with this geometry .Â
1) One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. Â However, meshing might be successful on the other entities. ->Â I have know this will happen but before I generate mesh I tried fix this with create midsurface because thin surfaces . However , still on the same result
2) One or more surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology. -> I have tried this fix with virtual topology with set virtual topology into repair all or automatic still get same result.
3) A mesh could not be generated using the current meshing options and settings. -> If the above have been fixed I thought this won't appear.Â
 beside that I have read another article , which is select capture curvature and capture proximity to turn on . but get the error , "A mesh could not be generated using the current meshing options and settings". Please I need help from someone , and I appriciate that. and thank youÂ
November 11, 2024 at 5:27 pm
mohan.urs
Ansys EmployeeHey,
Can you duplicate the model and generate a mesh using the default settings without changing anything, does that work ?
Can you share a snipshot of the geometry that you are using to generate the mesh ?
Does it only have shell surfaces after you used mid surfacing tool?Regards,
Mohan Urs -
November 12, 2024 at 2:14 am
SubscriberÂ
Can you duplicate the model and generate a mesh using the default settings without changing anything, does that work ? I have do that but still have same resultÂ
Can you share a snipshot of the geometry that you are using to generate the mesh ? yes , I share the geometry to you , look at the below . the geometry is hollow beam with thickness overall 10 mm and arranged like that .Â
Does it only have shell surfaces after you used mid surfacing tool? yes , exactly.ÂPlease give me a help like advice to make meshing into succesful
November 12, 2024 at 4:59 am
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
