February 27, 2023 at 12:58 pmBorut OmerzoSubscriber
Hi everyone.Â
Is it possible to manually change the temperature in a cell zone in Fluent (2022 R2)?Â
For example, if I have a rectangular duct 0.5 × 0.5 m, which is 2 m long, and in the middle, there is a zone 0.1 m thick. If I wanted to change the temperature in that zone to, say, 400K and make the downstream air acquire that temperature without using heat suorce, which UDF should I use?Â
I'm working on this because I want to model an adiabatic cooler, where the temperature changes relative to humidity. For that purpose, I modeled humidifying of the air, however, the last step is to assign a temperature to a cell zone in relevance to humidity.Â
My idea is to write a code in which I would write something like T = f(RH).
Sincerely
February 27, 2023 at 2:22 pmRobForum Moderator
If the zone is bounded by walls you can set the temperature. Otherwise, have a look at the FIX option in the cell zone panel.Â
- The topic ‘Manually changing the temperature in cell zone.’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Cyclone (Stairmand) simulation using RSM
- Fluent fails with Intel MPI protocol on 2 nodes
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
1216
543
523
225
209
