TAGGED: cfd-fluent, cfdsimulation, fluent-cfd, fluent-cfd-ansys
February 2, 2024 at 8:47 am
Dylan Ellul
SubscriberHi I am currently designing a pipe system where heat is applied to the exterior of the pipe, which in terms heat the inside water. Is there a way so that the output temperature becomes the input temperature for the next design points in paramaterization? I am doing this so that the mesh remains great and constant, instead of varying the length. Is there a way to do it with parameters or expressions inside Fluent please? Thanking you in advance.
February 2, 2024 at 11:14 am
Forum ModeratorProfiles can be used to transfer the data from one model to another, but in this case you'll need to take care to adjust the position of the profile: ie the x, y, and z coordinates will need adjusting.Â
Periodic flow is another consideration, please read the limitations in both flow and energy sections of the Fluent User's Guide.Â
- The topic ‘Making an output parameter an input parameter in the next design point’ is closed to new replies.
2778
965
841
599
591
