November 10, 2020 at 7:14 pmsusunSubscriber
I am trying to complete the license setting in LS-Run but having trouble with it.
As I have a license server, I selected the License type as Network, and typed the server hostname as it is demonstrated in the ANSLIC ADMIN Utility.
However, I'm receiving the error that they cannot retrieve license info from the server.
Can anyone point me in the right direction to solve this issue?
PS. I was connected to VPN which is essential to access the license server.
Thank you,
susun
November 11, 2020 at 1:19 pmMangeshANSYSAnsys EmployeeHello nSet license type to ANSYS if ANSYS LS-Dyna, if this was procured directly from LST in the past then use Network. Look for environment variable LSTC_LICENSE=ANSYSnPlease contact the license server administrator to confirm license type and port number if needed and that the ports used by License Manager are opened in any Firewalls nThis should allow you to runnRegardsnNovember 11, 2020 at 8:37 pmsusunSubscriberHello, nThank you for your answer.nAs I am using LS-Dyna from the ANSYS Structure package, I guess it is ANSYS LS-Dyna. However, I still get the message that the license info cannot be retrieved. nAlso, I was using the ANSYS product without License Manager since my school provided me with the license server.nI would appreciate any further help..nThank you.nBest,nnNovember 16, 2020 at 9:27 pmsusunSubscriberHello MangeshANSYS,nnI could check that my license server setup under ANSLIC ADMIN is correct and I could run Ansys Mechanical, however, still getting problem with LS-Run.nTherefore, can I ask you where I can find the environment variable LSTC_LICENSE=ANSYS? nMaybe I should check it preferentially.nnThank you.nViewing 3 reply threads- The topic ‘LS-Run License setting issues’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Workbench license error
- Unexpected error on Workbench: Root element not found.
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Questions and recommendations: Septum Horn Antenna
- AQWA: Hydrodynamic response error
- Tutorial or Help for 2 way FSI
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- 2 way coupled FSI for ball bearing
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
Top Contributors-
1416
599
591
565
366
