The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Ansys Products
Ansys Products
LS-Dyna Beam elements outputs
    • Fady Elshazly
      I am trying to read the stresses and strains for beam elements in Ls-Dyna. However I can see that only axial strain is available. Moreover, to get the maximum value over the run time, I have to choose either max or min.
      1-Are there any types of strain that I can read and get the max values for?
      2- What are the components (internal forces) that are included in the axial strain value?
      3- Is there a way to get the maximum absolute value?
      4-How to read bending strain only?
      Thanks
    • Armin
      Hi Fady,
      Did you get a chance to follow the workflow provided in your earlier post: LS-Dyna beam stress and strain (ansys.com)
      In short, set BEAMIP under DATABASE_EXTENT_BINARY card to a value greater than zero (depending on the number of integration points in your model), and then some of the beam results you’re looking for become available.
    • Fady Elshazly
      Thanks for the reply. I have already done so and I see these options (Axial, plastic strain and von mises stress). However, I am wondering if i can read other forms of stresses and strains such as bending strain separately. Are there any other options for stresses and strains?
      Thanks
