September 3, 2024 at 4:29 pmnm169Subscriber
We have the following environment:
Licensing Server 2024 R2
2024 R2 Client Software
Ansys Academic Teaching Mechanical and CFD (25 tasks)When attempting to log in to Workbench or Chemkin they receive the error: Could not connect to a valid licensing server. Review your licensing configuration in the Ansys Licensing settings application and make sure you are connected to a valid network.
The licensing tool autopopulates 1055@ipaddress and tests successfully, but when attempting to save, reports could not set FlexNet servers.Attempting to find an answer in the existing forums often references Student software and suggests no need for licensing, but no solution for academic versions. Our students are actively attempting to utilize this software in labs at this time.
September 3, 2024 at 8:10 pmbalconbjSubscriber
I am recieving same error  i have two laptop one works (windows 10) and windows 11 give me the error
September 4, 2024 at 11:05 pmDivya Shree SurendranAnsys Employee
Hi Nick,
Have you tried opening the ANSYS Licensing settings tool with Run as admin? This is required to save the license information
- Speed up simulation in HFSS
- RSS is disabled.
- ANSYS DISPLAY RESOLUTION PROBLEM
- Workbench license error
- ansys fluent error when opening it “unexpected license problem”
- Could not connect to a valid licensing server
- Ansys 2024 R1 – The installation completed with warnings/errors.
- Unexpected error on Workbench: Root element not found.
- LS-Dyna Beam elements outputs
1081
447
395
225
201
