October 27, 2021 at 12:00 pm
majam
SubscriberHello,
I am simulating a mixing tank with 3 moving regions (impeller regions) and one stagnant one (the rest of the tank).
After the flow becomes steady I wish to add a scalar source term in a region inside the tank (the stagnant region) . I want the source term to be in a specific region (for instance a sphere with diameter 0f 1-2 cm near the tank surface).
If I add the source term without identifying a region it will be applied to the whole tank not only a small region.
I was thinking if I define a region inside the tank (using adapt /refine/new region), then use an expression in the source term.
I am not sure though how to define the expression in the source term the way that source term will be generated only at that specific location.
I would appreciate it if anyone can help me?
October 27, 2021 at 12:33 pmRob
Forum ModeratorNot quite (rather, not yet). You need to split the cells zone using the register and then apply the source to the new zone.
October 27, 2021 at 1:16 pmmajam
SubscriberThank you for your response.
In this case, is it better to create a separate region when I am developing the Geometry (in design modeler or space claim) or just separating the cell zone in fluent is fine? or either way I am getting the same results?
ThanksOctober 27, 2021 at 1:33 pmaitor.amatriain
SubscriberYou could also include some "if" statements in the definition of the source term so that it vanishes outside the desired zone.
October 27, 2021 at 1:37 pmRob
Forum ModeratorThat works too.
Viewing 4 reply threads- The topic ‘Location of a source term in fluid region’ is closed to new replies.
5669
1890
1419
1304
