September 25, 2019 at 3:10 pmmichaelmaaloulySubscriber
Hello,Â
I am simulating liquid CO2 flowing through a pipe with heat transfer. The CO2 enter as CO2 mixture between liquid-gas at 10 bar and -40 C, it gets cooled down midway; therefore, the vapor quality of the CO2 changes.Â
Is there any way to enter the full liquid and gas properties for the CO2 (in a table format for example), or do I have to add new material with the CO2 properties at 10 bar -40 C in both phases?Â
My concern is that the pressure will drop throughout the pipe, so the properties will change as the pressure changes.
Thank you.
September 25, 2019 at 4:08 pmRobForum Moderator
You'll use a multiphase model (probably Eulerian) and have two materials: CO2-liquid and CO2-gas. Then use a phase interaction model for the evaporation/condensation.Â
September 25, 2019 at 4:52 pmmichaelmaaloulySubscriberYes, that's what I am doing, but I am concerned about the liquid and gas CO2 properties. I want to see if I can import a table of properties for the CO2 to accommodate the change in pressure, because when you add a new material you set the properties for one specific temperature and pressure.
June 30, 2023 at 2:02 amShamkhal MammadovSubscriber
I am trying to do something similar. I am dealing with 2 d pipe, 3 inches by 12 ft. I am injecting CO2 at 1200 psi, 26 deg C (inlet condition), and my outlet condition is 200 psi, as I know from thermodynamics, co2 will change phase from liquid to gas, how can visualize this process?Â
- The topic ‘liquid gas CO2 multiphase using Fluent’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Fluent fails with Intel MPI protocol on 2 nodes
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script error Code: 800a000d
- Encountering Error in Heterogeneous Surface Reaction
1191
513
488
225
209
