August 28, 2024 at 9:04 am
quoctran0606
SubscriberI get the error as the attached image below. I try to simulate the laying barge with a stinger+ extension stinger.
My process to build a stinger and extension stinger is by using line body data with a cross-section in Modeler.
I use 3 hinged connection between the barge with the stinger and ball&socket btw stinger with an extension stinger.
Could you please help me explain what happen with my model and please give me suggestion in this case?
BTW is there any example model for this type of simulation?
September 2, 2024 at 12:07 pm
Ashish Khemka
Forum ModeratorHello,
Please see if the following forum thread helps: Errors with multi-connected bodies using AQWA (ansys.com)
Ashish Khemka
1565
1386
1242
