TAGGED: ansys-innovation-courses, fluids, heat-transfer
February 11, 2021 at 4:06 pmKarthik RemellaAdministratorFebruary 11, 2021 at 4:06 pmKarthik RemellaAdministratornnMarch 21, 2021 at 4:12 pmMarch 22, 2021 at 11:53 amKarthik RemellaAdministratorHello,nThanks for connecting with us here. How are you opening these files? Could you launch a Fluent 2021R1 stand-alone session and try to read the cas and dat files?nTo launch Fluent: Start -> Fluent 2021R1 (open in 3D double precision).nLet me know if this helps.nKarthiknMarch 22, 2021 at 6:52 pmvineet123SubscriberI am just double clicking the files after extracting it , The steps you told are working and files are now opening ncan you tell how to get the geometry of the file .nthankyou so muchnregardnVineetnMarch 22, 2021 at 7:45 pmKarthik RemellaAdministratorHello,nI'm glad that this is working. Since our analysis starts with the mesh file, please use the provided mesh file, watch the video, and see if you are able to set-up this problem. Here is the link to the video.nAlso, if you need the geometry file for some reason, you should be able to create something similar using Ansys SpaceClaim. nKarthiknOctober 6, 2023 at 1:04 amNoriya ShimozatoSubscriber
モンテカルロ法による輻射熱解析について立方体外気流体をAIRと定義しその中に熱源があるモデルです。AIR流体に輻射を考慮するにチェックを入れて解析を流し外気流体の温度コンター図を観てますが輻射熱の分布と考えて良いのか?
Viewing 6 reply threads- The topic ‘Introducing: Intro to Heat Transfer in Fluids’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
Top Contributors-
1937
865
599
591
366
