Ansys Products
Ansys Products
Insufficient HPC licenses available
    • Rashi
      I'm running ANSYS 2020 R2 on an RHELS 7.9 workstation with 32 physical cores.
      I can only run a simulation up to 8 cores and when I go above 8 cores simulation does not run. When I check solver output, it shows "insufficient HPC licenses available".
      I ran the ANSLIC_ADMIN utility and in the HPC license list, there was one HPC license available. Please let me know how to solve this issue.
      Thank you.
      Rashi.
    • George Karnos
      Can you post the license status?
    • Rashi
      Hi Geo
      Following is the license status I got from anslic_admin
      Oct 11, 2021 22:19: Attempting to display the license status...
      DISPLAY THE LICENSE STATUS:
      Note: ANS_FLEXLM_DISABLE_DEFLICPATH environment variable is set.
      ANSYS Licensing Interconnect path = 2325@a2.cmc.ca
      ANSYS FLEXlm license path = 6624@a2.cmc.ca
      ***** Note: Due to a FLEXlm limitation, all tasks may not be found *****
      ***** LICENSE SERVER STATUS: 6624@a2.cmc.ca *****
      lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
      Flexible License Manager status on Mon 10/11/2021 22:19
      [Detecting lmgrd processes...]
      Error getting status: License server machine is down or not responding. (-96,491)
      Can you check if you can run with 4 and then 5 cores?
    • Rashi
      Hi Rob
      Yes, I can run with more than 4 cores now. It seems I've maxed out the licenses available for our research group.
      Please mark this case as resolved.
      Thank you.
      Rashi
      :) The base solver currently gives you 4 parallel, then HPC adds from there. One pack is 12 (8+4) cpu, 2 packs 36 (32+4), 3 packs 132 (128+4) etc. I'm sure your account manager can help with additional licences.... ;)
    • Rashi
      Hi Rob According to the license provider (CMC microsystems), we have 60 cores for simulation with the HPC pack. That is an odd number don't you think?
      Rashi
      It looks odd but could be a pool rather than a pack. The former is a lot more flexible and is how we used to supply parallel.
    • Rashi
      Thank you for your reply Rob.
Viewing 8 reply threads
  • The topic ‘Insufficient HPC licenses available’ is closed to new replies.
