April 13, 2022 at 8:30 am
tomas.monopoli
SubscriberHello,
I am trying to install Ansys Electronic Desktop on a Centos 7 operating system.
I installed the reuirement packages specified in the installation guide. When I run the install file in the download, the installation shell opens correctly. However when I click on install EM suite, the process blocks at the following step:
April 15, 2022 at 12:22 pmrandyk
Forum ModeratorHi Tomas I'd suggest you use a silent installation mode.
To install Ansys Electronics uses InstallShield.
These are the generic steps I tend to recommend for AEDT silent install on Linux
1.. extract AEDT media to /tmp
2.. create/edit /tmp/AEDT/silAEDT.iss
$ cp /tmp/AEDT/Electronics_xxx_linx64/Linux/AnsysEM/disk1/SilentInstallationTemplate.iss /tmp/AEDT/silAEDT.iss
edit:
line 46:-W GroupPanel.groupID="root"
line 69: -P installLocation="/opt/AnsysEM"
line 81: -W TempDirectory.tempPath="/tmp"
3.. install
$ /tmp/AEDT/Electronics_xxx_linx64/Linux/AnsysEM/disk1/setup.exe -options "/tmp/AEDT/silAEDT.iss" -silent
4.. fix license and tempdirectory
When complete edit the following files to specify correct license and tempdirectory:
/shared_files/licensing/ansyslmd.ini
/AnsysEMxx.x/Linux64/config/default.cfg
5.. To run AnsysEM/AnsysEMxx.x/Linux64/ansysedt
If need AnsoftRSMService, that is done by:
Create the /tmp/rsm.iss(correct path and owner as needed)
-W Agree.selection=1
Run the following:
sudo /path/Electronics_xxx_linx64/Linux/RSM/disk1/setup.exe -options "/tmp/rsm.iss" -silent
sudo /opt/AnsysEM/rsm/Linux64/ansoftrsmservice startonboot
-- register AnsysEM so AnsoftRSMService can find the solver/comm engines.
sudo /opt/AnsysEM/AnsysEMxx.x/Linux64/RegisterEnginesWithRSM.pl add
To silent install theV22r1.2 patch in Linux
$ tar -xzvf ./ELECTRONICS_2022R1.02_LINX64.zip
$ cd //AnsysEM/Electronics_22.1.2_linx64
$ ./install_patch.bash --force_overwrite --install_dir //AnsysEM
$ cat //AnsysEM/v221/Linux64/product.info
should result in:
AnsProductName="ANSYS Electromagnetics"
AnsProductVersion="22.1.2"
AnsProductOS="Linux"
AnsProductBuildDate="2022-02-23 19:11:24"
Hope this helps
-Randy
April 20, 2022 at 3:18 pmtomas.monopoli
SubscriberThank you vary much for your answer Randy.
I installed AEDT following the steps you described.
I get an error:
However, if I run sudo yum install libXss.so.1 , it seems the package is already installed:
I attach the full lld output log in case it can be useful.
Also, I have (I think ) correctly inserted the ANSYS FLEXlm port number and Hostname for the licence in config file. However, I didn't find where to insert the ANSYS Licencing Interconnect Port Number.
Thank you Tomas
April 20, 2022 at 3:42 pmrandyk
Forum ModeratorHi Tomas Please try: sudo yum install -y libXScrnSaver libXss.so.1
After, confirm the library is in place: ls -al /usr/lib64/libXss*
ex:
-bash-4.1$ ls -al /usr/lib64/libXss*
lrwxrwxrwx. 1 root root15 Dec 132016 /usr/lib64/libXss.so.1 -> libXss.so.1.0.0
-rwxr-xr-x. 1 root root 13520 Feb 212013 /usr/lib64/libXss.so.1.0.0
-bash-4.1$
thanks
Randy
April 26, 2022 at 2:13 pmtomas.monopoli
SubscriberThank you very much! The installation now works correctly :)
December 13, 2022 at 8:45 pmViewing 5 reply threads- The topic ‘Installshield Wizard blocks during installation of Electronic Desktop on Centos 7’ is closed to new replies.
