Ansys Products
Ansys Products
installation, Licensing & Systems
    • jpkizito
      I need help.  I have Linux 7.6 and I have downloaded 2019 R2 version of Ansys.
      I cannot load license.
      UploadLicenseFile 2019/06/08 20:48:48 Error: Cannot run program "/usr/ansys_inc/shared_files/licensing/linx64/lmutil": error=2, No such file or directory 2019/06/08 20:48:48 Error: 3
      Can I get help?
    • jpkizito
      Can I get help?
    • tsiriaks
      What is the name of the installation package that you used ?
      Where are you seeing this error ? Please post the screenshot of the entire window that contains this error message.
      Thanks,
      Win
    • jpkizito
      Thanks Win.
      The issue has been resolved.  The problem was lmgrd and lmutil could not work on Linux (7.6) without more files.  Once these (Linux Standard Base package) were added the problem was solved.
      jpkizito
    • tsiriaks
      Ah I see. You are right, we've also seen this issue when system is missing LSB.
      Thank you for the update.
      Win
Viewing 4 reply threads
  • The topic ‘installation, Licensing & Systems’ is closed to new replies.
