LS Dyna
LS Dyna
Initial Velocity Generation
    • valerym.m5
      Good day,
      I have encountered many times a situation that is incomprehensible to me, setting the initial speed:
      setting the speed direction (-/+) is interpreted in the program UNPREDICTABLY.
      in particular, in the attached file the speed is set with the "+" sign - i.e. the direction is up,
      but the body = to which the speed is applied - moves down, as I need
      maybe I am making mistakes somewhere... or using the program settings incorrectly?
      https://drive.google.com/file/d/1UgAJFev6nbMneTF-GcsvzFqwRH2cFDL6/view?usp=sharing
    • Pedram Samadian
      Hi Valerym,
      I created a simple cube tensile model and applied the same keyword card to define an initial velocity. As can be seen below, the displacements are positive as expected given the positive y-velocity provided. STYP in my model is 2 (i.e part ID) but is 1 in your model (i.e. part set ID). Make sure that your "part set #1" only includes the part you want to apply the initial velocity, not any other parts.
      Thanks,
      Pedram
    • valerym.m5
      Dear Pedram,
      Thank you for your advice.
      I checked the correctness of the initial velocity assignment in my model - everything is set correctly there.
      It was not by chance that I applied the term "unpredictable" to the assignment of the initial velocity for a rigid body.
      I have already had several cases when the model correctly perceives the direction of the initial velocity, but then - in the process of some changes in the model, the specified direction of the initial velocity is perceived by LS-DYNA as the opposite, although I did not redefine the direction of the initial velocity.
      *** Unfortunately, I have never been able to "fix" - at what stage of the model change LS-DYNA stops correctly perceiving the specified direction of the initial velocity.
      As for your advice - to set the initial velocity for a specific part of the model - I will try to do this now and will write to you about the results.
      Regards Valery
    • valerym.m5
      Dear Pedram,
      I followed your advice – I set the initial speed for a specific part.
      the model can be obtained from the specified link:
      https://drive.google.com/file/d/1qKZq45Eu8MOuKVOMhO2-eEMXLpvbiQLV/view?usp=drive_link
      to my regret, LS-DYNA perceives the set initial speed incorrectly:
      initial speed = – 2800 mm per second, direction down.
      but as you can see the part moves up.
    • Pedram Samadian
      Thanks for the details. I am not sure which part the initial velocity was assigned to, but my guess is one part is hitting the other part based on this given velocity, and after the collision, the colliding part changes its moving direction. If that is the case, the reason you do not see the transfer of you part along the expected orientation before the collision might be the low output interval you set. Ensure your output interval in the DATABASE keyword cards is high enough to increase the resolution of the results (more data along the time).
      Please keep me posted.
      Thanks,
      Pedram
    • valerym.m5
      the solution step is quite small:
      dt 1.72E-07
      in addition, if there was an impact/contact with bodies lying below the load, then a wave pattern would be visible in the parts where the material has viscous properties.
    • Pedram Samadian
      How long does it take for the part with velocity to reach the stationary part?
      I also see the time-integration scheme has changed from implicit to explicit at some point. The implicit time steps are much higher than the explicit ones. What was the time step size for the implicit portion of the simulation?
      • valerym.m5
        the gap between parts = 1.02 mm
        initial speed 2800 mm per second
        time it takes to start contact = 0.000364 seconds
      • valerym.m5
        this is the curve of maximum values ​​of the solution step for the implicit solver
    • valerym.m5
      by the way, getting/writing calculation results according to the curve with sequential use of implicit and explicit solver is also a problem for me - which I wrote about here:
      https://innovationspace.ansys.com/forum/forums/topic/restart-switch-implicit-gt-explicit/
    • Pedram Samadian
      Hi Valery,
      Thanks for the details. Unfortunately, I cannot download your model here to figure out what is going on in your model unless you can send it through Ansys Customer Support Space (ACSS).
      The contact is established after 0.000364 s, so please ensure that your output interval for d3plot (in *DATABASE_BINARY_D3PLOT) in the implicit portion of your simulation is lower than this. Then plot the velocity history of the part. The velocity sign must be consistent with the direction of the part movement in each output within the period of 0 s to 0.000364 s.
      Thanks,
      Pedram
    • valerym.m5
      Dear Pedram,
      I will definitely take advantage of your kind offer.
      But first I would like to make sure that my assumptions are correct.
      So:
      1. I could not learn to regulate the recording of calculation results at the initial stage of using an explicit solver.
      For some unknown reason, the program ignores my instructions and writes the calculation results “arbitrarily” – immediately after switching the solver type – in this model – about 0.02 seconds.
      After 0.02 seconds, the results are recorded with a step “close” to the required step, but still not exactly to my requirements specified in the curve.
      •  I am interested in the calculation results at the initial moment of time – at the moment of impact of the load.
      2. Since I couldn’t solve the 1st problem, I tried to use the command:
      Velocity_Generation_Start_Time
      Where, according to the documentation, you can set a “delay” in time for the initial velocity applied to the “rigid” body.
      However, ls-dyna ignores any specified delay values ​​and the initial velocity is activated at the moment of switching from the implicit to the explicit solver.
      3. Taking into account my unsuccessful attempts 1 and 2.
      I decided to achieve the required delay in the time of application of the initial velocity by moving the falling load a distance that I calculated from the specified initial velocity of 1000 mm per second.
      However, from the analysis of the solution I found that the initial velocity of the load is not 1000 mm per second, but 2567 mm per second!
      0.00805664 sec is the time of motion of the rigid body
      20.68639946 mm is the distance the rigid body has moved
      2567.62117458 mm/sec is the constant speed of motion
      If someone wants to get acquainted with my model – see the link below
      https://drive.google.com/file/d/1jf3XCB1v87ImHqMO-PfN6SXNVcTPGAUT/view?usp=sharing
      I will be very grateful for any advice – since in this case I have a stalemate.
      I tried to solve this problem with other data – trying to understand possible patterns, and I was very surprised, since the initial speed given was different each time?!
      Below is another example of the solution
      timeUy
      10.00000000.0000000
      10.016828520.1738129
      10.021549225.8324966
      10.022872927.4195175
      10.023862828.6061802
      10.024841329.7792721
      10.025808330.9385910
      10.026764932.0844803
      10.027710033.2173271
      10.028643634.3369370
      10.029566835.4437866
      10.030479436.5377007
      10.031381637.6189613
      10.032273338.6876526
      10.033154539.7442780
      10.034025240.7885284
      10.034886441.8205681
      10.035738042.8409538
      10.036579143.8493919
      10.037410744.8462029
      10.038232845.8315926
      10.039045346.8054848
      10.039848347.7680931
      10.040641848.7197609
      10.041426749.6601524
      10.042202050.5898819
      10.042968851.5088005
      10.043726052.4171677
      10.044475653.3149796
      10.045215654.2024994
      10.045947155.0797882
      10.046670955.9469223
      10.047385256.8037834
      10.048091957.6509781
      10.048790958.4884300
      10.049481459.3161201
      10.050164260.1341667
      10.050838560.9428711
      10.051505161.7423515
      10.052164162.5323830
      10.052816463.3134384
      10.053460164.0852509
      Dt0.0534601
      D_Uy64.0852509
      speed1198.7487
      For the last solution, the initial speed was specified -2800 mm per second,
      but in reality – according to the calculation – the speed was 1198 mm per second
    • valerym.m5
      here is another fact - which I cannot understand:
      judging by the graph - the initial velocity of the rigid body increases over a fairly long period of time.
      I do not specify this period of time...
      ls-dyan somehow determines it itself.....
      Nothing is said about this in the documentation... - to be more precise, I did not find anything
      hence the question:
      and how then can one specify the initial velocity of the rigid body - without the "acceleration time"??
      Is it possible to do this at all?
      and one more question:
      I specify the initial velocity of 1000 mm per second, and here again ls-dyan "acts up"... - the velocity - judging by the graph:
      1.1987445068e+03 mm per second
      1.0016828537e+01 1.1987445068e+03
    • valerym.m5
      in my model, the parameter PHASE:=0
      EQ.0. Velocities applied immediately
      but if I understand the calculation results correctly, then ls-dyna solves the problem with the parameter PHASE:=0 EQ.1. Velocities applied after dynamic relaxation.
      and with this ls-dyna somehow independently calculates the period of dynamic relaxation and for some reason it also changes the amplitude/magnitude of the initial velocity that I set.
    • Pedram Samadian
      Hi Valery,
      Can you please show your specified output interval histroy that includes both the implicit and explicit parts of your model? The image in your 4th comment shows that as the solver changes from implicit to explicit, an output is written in the d3plot. Where is that 0.02 second gap?
      The *LSO_TIME_SEQUENCE card may also help you for managing output writing (LS-DYNA Multiphysics Manual).
      Using Velocity_Generation_Start_Time, the initial velocity occurs only in the regular transient phase after dynamic relaxation (if used). Neither PHASE value will cause initial velocity to be imposed in the dynamic relaxation phase. It is surprising that the velocity does not start from what you specified, but given the previous explanation, maybe dynamic relation is being applied during that period.
      Please also make sure to use the lastest LS-DYNA solver downloadable at LS-DYNA (user=user) Download Page(username: user & password: computer). The double precision type is recommended.
      I hope this information helps you.
      Pedram
      • valerym.m5
        Good day Pedra
        thank you for your recommendations.
        As for the curves concerning the maximum value of the integration step and the step of output of the calculation results – they are in the model.
        But as far as I understand, if the model uses switching from an implicit to an explicit solver,
        then in this case – ls-dyna does not want to fulfill the exact requirements for output of the calculation results specified in the curve.
        it not only writes the results “arbitrarily”, but also changes the “prescribed” value of the initial velocity – as a rule, to a greater one.
        maybe I’m wrong about something – since my experience with ls-dyna is very modest.
        So I hope to hear the opinion of more qualified engineers.
        Reagrds Valery
    • valerym.m5
      Dear colleagues,
      I offer you two models that demonstrate “oddities” that I could not understand.
      I will be glad if you write your assumptions… advice…. comments…
      Model
      STYP-2_Relax.key
      Link to the model:
      https://drive.google.com/file/d/1P3C9CnTEGN145BxeU_X8ALUofHXnlTHp/view?usp=sharing
      The initial speed of the cargo is set: -1000 mm per second
      The cargo moves down.
      As the calculation results show, the load receives a real initial speed in the calculation: -2594.6645508 mm per second
      during the rise time: 0.00009155 sec – see below
      Vy.txt
      3.6099996948e+02 0.0000000000e+00
      3.6100009155e+02 -2.5946645508e+03
      3.6100531006e+02 -2.5946645508e+03
      Model
      No_Relax_1.222e-4-1000mm_0_023sec.key
      link to the model :
      https://drive.google.com/file/d/1eOWIbv6e2wMkJ7HqZMFYVccMiwD1LyFJ/view?usp=sharing
      The initial velocity of the cargo is set: -1000 mm per second
      The cargo moves up.
      Curveplot
      Nodal History
      Time
      Y-velocity
      Node no.
      222980 #pts=266
      * Minval= -1.0000000000e+03 at time= 0.0000000000
      * Maxval= 3.7985620117e+03 at time= 10.0000991821
      9.9999990463e+00 0.0000000000e+00
      1.0000099182e+01 3.7985620117e+03
      1.0001098633e+01 3.7985620117e+03
      List of questions I wanted to would like to get answers:
      1. why, when setting one “initial” speed – 1000 mm per second,
      in the first model – the cargo moves down, and in the second model – the cargo moves up?
      2. why, when setting one “initial” speed – 1000 mm per second,
      in the first model – the actual speed of the cargo according to calculations = - (MINUS) 2594.6645508 mm per second,
      and in the second model – the actual speed of the cargo according to calculations = + (PLUS) 3798.5620117  mm per second?
      3. Why do the above “initial” speeds reach constant values ​​in different times?
    • valerym.m5
      by the way, here is another model where the initial speed is given with a plus sign:
      +1000 mm per second
      https://drive.google.com/file/d/1xZ0Byw0l9EbzeD-TFVCRAJDfirI0DbcJ/view?usp=sharing
      but in fact, according to calculations - the speed is NEGATIVE = - 1117 mm per second
      9.9497890472e+00 0.0000000000e+00
      1.0000000000e+01 0.0000000000e+00
      1.0008694649e+01 -1.1772938232e+03
      1.0009955406e+01 -1.1772938232e+03
      i.e. a body with a given positive speed = +1000 mm per second should move up, but for some reason the body moves down?!
    • Pedram Samadian
      Hi Valery,
      Please remove any relevant mass scaling and dynamic relaxation cards (e.g. control_timestep and control_dynamic_relaxation) from the model and then run it.
      Please keep me posted on the outcome.
      Thanks,
      Pedram
      • valerym.m5
        Hi Pedram,
        unfortunately, removing the mentioned cards did not produce any positive results.
        Regards Valery
    • valerym.m5
      Hi Pedram,
      thank you very much for your advice – I will try to use your advice.
      However, I hope to get answers to my questions from more qualified colleagues.
      I find it hard to believe that no one has tried to solve such problems before and tried to figure out what is going on?
      To my regret, I could not find even a brief description of the "actions" of the program
      when switching solvers (implicit <=> explicit) occurs using a curve.
      Maybe someone has already found at least some information on this issue?
      Regards Valery
    • Pedram Samadian
      Hi Valery,
      I am sorry that the issue is still persisting. Unfortunately, I cannot reproduce the error you are getting in simple models I created. In my last try, I built a simple impact model and used the initial velicity generation card and a combined implicit-explicit time integration scheme (implicit before collision and explicit after that). In the predictions, the part moved in the same direction as that specified in the initial velicity generation card until the collision and could get recordings at the preset time intervals, including the exact time when the explicit solver starts working (you can see it in the image below).
      We need to review your model in detail to see what the problem is. As I noted, Ansys employees cannot download or upload files on the Forum platform, but it can be done through Ansys Customer Support Space (ACSS) after users open a ticket.
      Thanks,
      Pedram
    • valerym.m5
      Dear Pergam,
      probably I did not explain the problems clearly enough.
      The issue is not that the solvers would switch at the required time.
      I will briefly list the main problems again
      1. the start time of the initial velocity application specified in the map “Velocity_Generation_Start_Time” is ignored
      2. ls-dyan arbitrarily changes the value of the specified initial velocity, when using the technology of switching solvers during the solution of the problem.
      for example – the initial velocity is set to – (minus) 1000, and from the analysis of the obtained solution – the real initial velocity is – (minus) 2594!
      Moreover, there were cases when – the initial velocity is set to – (minus) 1000, and from the analysis of the obtained solution – the real initial velocity is + (PLUS) 2594!
      3. Completely incomprehensible cases occur, for example:
      as a result of setting a negative value of the initial velocity, the body should move downwards, but in some cases – it starts moving upwards!
      There were other cases (numerous) – when a positive initial velocity was set, and the body began to move downwards!
      Regards Valery
    • valerym.m5
      here is another "incomprehensible" example:
      https://drive.google.com/file/d/1wkfTCIeIb8E_D7I4P8pYGQTSjuPKUWTd/view?usp=sharing
      first option - initial velocity is set to - (minus) 992 mm/sec
      real initial velocity during solution analysis is -2331 mm/sec
      as it should be - the body moves down
      second option - initial velocity is set to - (minus) 1102 mm/sec
      real initial velocity during solution analysis is + (plus) 2717 2.7169147949e+03 mm/sec
      the body moves up!!
      the model is used without any changes!
      only the initial velocity changes!
    • valerym.m5
      another "strange" situation:
      below is a link to the model
      https://drive.google.com/file/d/1X9HhXJ6nybtnQQrRoOcq9eNykMJVEnBf/view?usp=sharing
      initially, this model used an elastic material for steel plates.
      the initial speed was set to 1075 mm per second,
      the real initial speed - with which the problem was solved was 2571 mm per second.
      Ok!
      it is already good that the displacement corresponds to the sign of the speed
      but when I added the elastic-plastic material MAT_03 to this model - the load began to move up, not down!!!
      nothing changed except the new model MAT_03 introduced.
      it would be very useful to hear hypotheses regarding the question:
      How can a new material change the direction of movement?
      Maybe I don't understand something?
    • Pedram Samadian
      Hi Valery,
      I encountered a reported bug for the initia velocity generation keyword that might have been making a problem for your model. If my guess is correct, changing the set type in the card (STYP) to a node set should fix the issue.
      I look forward to your feedback.
      Thanks,
      Pedram
    • valerym.m5
      Dear Pedram,
      previously, I experimented with the card (STYP) many times.
      Unfortunately, I never got a positive result.
      Probably, the reasons for "complete uncontrollability" when setting the initial speed with an offset are much more serious.
      Regards Valery
    • Pedram Samadian
      Hi Valery,
      Thanks for the feedback. Another workaround is to use the R16 solver, which should be released in coming days. The bug in the Initial Velocity Generation card has been fixed in this solver.
      Cheers,
      Pedram
    • valerym.m5
      Dear Pedram
      thanks for your kindness.
      I’ll wait for this version.
      Will the new version fix the map Velocity_Genertion_Start_Time ?
      Regars Valery
    • Pedram Samadian
      Hi Valery,
      Any bugs reported for different keywords should be fixed in the new solver. Try the new solver when it is released, and then give us feedback, please.
      Thanks,
      Pedram
Viewing 25 reply threads
