August 29, 2024 at 10:58 am
Abraham Thomas Chirathalattu
SubscriberHi,
I am trying to run a crash simulation and the above error termination occurs. It says retractor convergence failure at time 101.3ms. I am using LS-DYNA R13 double precision solver to run the job. Can anyone please help resolve the issue? the following are the restractor parameters used:Â
TDEL: 0.5
PULL: 5.0
LFED: 12.0
loading and unloading curves are defined and are based on coupon tests conducted.Â
September 3, 2024 at 2:32 pm
Ram Gopisetti
Ansys EmployeeHi Abraham,Â
This error can be triggered if the material type and/or load curve used in pull-in and pull-out for retractor may have a problem. Please check and make sure there is no unrealistic values set.
Cheers,Ram
December 7, 2024 at 11:28 am
99993959
SubscriberHI,Abraham,
Can you reslove it?I have a similar question:
*** Error 40057 (SOL+57) slipring 1000024:convergence failure at time1.01E+02
but I can't find the slipring 1000024 in my model.
5939
1307
