November 27, 2024 at 7:12 am
zxhurs
SubscriberHello,
I have a question regarding the application of Initial Stress Shell in tensile testing:
Using LS-DYNA version 4.11, under Application > Plastics Analysis > Import Data from Moldex3D, I obtained a set of Initial Stress Shell data for short fiber-reinforced composite injection molding. When I used this Initial Stress Shell data for tensile simulation, the test section of the shell suddenly disappeared. However, when I ran the tensile simulation without adding the Initial Stress Shell, the process proceeded normally.I am unsure whether it is inappropriate to directly add the Initial Stress Shell keyword for the simulation or if it was not correctly referenced.
I found some web pages related to history variables, but I couldn't determine what these six variables specifically represent. It seems that History Variable 1 corresponds to the tensor component a11​.
https://www.dynasupport.com/howtos/material/history-variablesAdditionally, could you please explain the application of the d3plot file under Post > Vector > HistVarCosine, particularly regarding the directions? I couldn’t find relevant information and wasn’t able to figure it out myself.
December 5, 2024 at 8:56 pm
Reno Genest
Ansys EmployeeHello,
Are the residual stresses that you import from Moldex3D in the correct unit system? Make sure you are using a consistent unit system:
https://lsdyna.ansys.com/consistent-units/
You will find more information about importing data from Moldex3D in LSPP at the end of *MAT_303 in the LS-DYNA Materials Manual.
Note that "the mapped data will be exported as material history state variables in the initial stress keyword cards *INITIAL_STRESS_SHELL or *INITIAL_STRESS_SOLID.".
Let me know how it goes.
Reno.
December 5, 2024 at 9:17 pm
Reno Genest
The Post > Vector > Hist. var. cosine is used to plot vectors of material direction using the material direction cosines stored in history variables for certain materials. You will find more information in the LS-DYNA User Manual Vol I: LS-DYNA Keyword Manual
Also, you can visualize material directions for composite material models as explained in the following LSPP presentation: Composite Capability in LS-PrePost.
Reno.
5834
