June 22, 2023 at 2:21 pm
1829116
SubscriberHiÂ
I am modelling an oven that heats a solid body. I am simulating the airflow in the oven using using FLUENT then importing the its charactersitics to Transient Thermal to apply as a heat load on the solid body. I try to simulate different inlet temperature of air to the oven in FLUENT but when I import the heat load to tranisent thermal, it does not seem t show any difference in the results.Any suggestions?
June 23, 2023 at 3:18 pm
- The topic ‘Importing heat load from FLUENT to Transient Thermal’ is closed to new replies.
