August 17, 2023 at 10:41 amChin-Hung LaiSubscriberI create a C beam with ACP, no matter i transform to shell or solid, even isotropic C beam without ACP, i fixed the end of the beam, set a moment with remote piont, but no matter i change the position of remote point, the result won't change, why? can anyone help me, thanks.
August 18, 2023 at 11:48 amAniketForum Moderator
Can you please explain the query possibly with some more inline images and more details?
-Aniket
August 18, 2023 at 1:19 pmAshish KhemkaForum Moderator
Hi, Can you please share the snapshot of the moment calculation? Also, please share why remote point change impacts moment calculation.
Ashish Kumar
- The topic ‘I change the position of remote point, but the result under moment won’t change’ is closed to new replies.
Ansys Innovation Space
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Image to file in Mechanical is bugged and does not show text
- Timestep range set for animation export
- Frictional No separation contact
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
594
591
540
366
