October 11, 2021 at 2:26 pmEzzadSubscriber
Hi, I am using DI_engine in Chemkin to analyze a diesel engine. I am trying to use higher compression ratios like 18 and 21 but the simulation failed. I assumed that the compression ratio used cannot be larger than 11.19585 as shown in the screenshot below
October 13, 2021 at 3:18 pmRKAnsys EmployeeHello,
When you used higher compression ratios, what was the error message that you got? And also, may I know which version you are using?
October 13, 2021 at 5:08 pmEzzadSubscriberHi I am using Chemkin-Pro 2021. The error message mentioned about the solution cannot converge.
October 13, 2021 at 7:00 pmRKAnsys EmployeeDo you remember the exact error message?
October 14, 2021 at 1:47 amViewing 4 reply threads- The topic ‘How to vary compression ratio in Chemkin?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
Top Contributors-
1341
591
584
525
366
