Ansys Products
Ansys Products
How to uninstall Ansys License Manager 2020R2 from license server
    • kilo
      Hello,nHow do I uninstall Ansys License Manager 2020 R2? It needs to be re-installed due to a stability issue, however, it is not found in Add/Remove programs in the Control Panel and an uninstall exe is also missing.nPlease provide some pointers for this.nThank you!n
    • ANSYS_MMadore
      Array You will want to run these commands from an Admin Command Prompt.nC:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_server -k uninstallnsc stop ANSYSLicensingTomcatnsc delete ANSYSLicensingTomcatnnThanksnMattn
    • kilo
      Thanks, mmadore. I am restarting the server to confirm that the service has been removed.n
    • kilo
      Worked great. Thanks for the help, mmadore!n
  • The topic ‘How to uninstall Ansys License Manager 2020R2 from license server’ is closed to new replies.
