TAGGED: ansys-spaceclaim, cad, equations, parameterize
September 2, 2021 at 12:16 pmelhamasadiSubscriber
Hi
I am trying to model the following hypothetical equation in Spaceclaim (to represent a defeatured plate):
z= (a*Sin(2*[u]))+(Sin([v]/[b])
So far, I know how to model an equation with 2 variables, but could anyone help me with such an equation that has multiple variables, please?
Here's what I have found in the ANSYS documentations, but I could not make it work!
September 2, 2021 at 2:07 pmErik KostsonAnsys Employee
I would add this post under the 3D design forum where the discussions are related to 3D CAD (e.g., SC).
Thank you
Erik
Viewing 1 reply thread- The topic ‘How to create a Parameter to use in the equation in Spaceclaim?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Image to file in Mechanical is bugged and does not show text
- Timestep range set for animation export
- Frictional No separation contact
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
Top Contributors-
1341
591
569
525
366
