August 13, 2023 at 6:46 am22503862Subscriber
The TUI command manual has the display/set/mirror-zones command, but no way to actually activate any of these zones, only set them as designated mirror zones. How do you actually turn them on in TUI?
August 13, 2023 at 7:35 amSRPAnsys Employee
TUI command display/set/mirror-zones shows sets the zones about which the domain is mirrored (symmetry planes).
Can you please elaborate more what you want to do?
Thank you
August 13, 2023 at 7:50 am22503862Subscriber
It turns out this was a GUI glitch. I had to close and reopen the views menu for it to take effect.
Thanks
- The topic ‘How do you activate mirror planes in the TUI?’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Cyclone (Stairmand) simulation using RSM
- error udf
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Encountering Error in Heterogeneous Surface Reaction
513
488
225
209
