September 7, 2021 at 5:55 am
332697296
SubscriberHi, I want to deploy ANSYS HPC with one head node and seven compute nodes on Linux. You need to use OpenhPC, Slurm. I've been looking for information for days, mostly to no avail. Do you have the details? thank you!
September 9, 2021 at 12:27 pmmhaselow
Ansys EmployeeHello,
what exactly are you looking for, what ANSYS products are you trying to deploy? OpenHPC and Slurm already installed and configured?
Thanks,
Michael
September 10, 2021 at 10:44 amdariusz.c90
SubscriberHi,
I am also setup SLURM based HPC, i have already configured SLURM cluster with two nodes and INTEL MPI. I have installed RSM on head node and shared the installation for compute nodes. I can run distributed mechanical on 1 node, but i cannot run distributed mechanical on 2 nodes. When I try this it run shared memory on 1 node on 1 CPU only.
October 9, 2021 at 8:50 am332697296
SubscriberI have installed OpenhPC and Slurm.How do I deploy after that?
Viewing 3 reply threads- The topic ‘How do I deploy ANSYS HPC’ is closed to new replies.
6114
