TAGGED: #fluent-#ansys, #fsi-#transient, 2-way-coupled-fsi, ansys, ansys-fluent, ansys-fluent-solver, ansys-mechanical-apdl, ansys-structural, ansys-workbench-mechancal, ansysfluent, ansysmechanical, anys-mechanical, coupled, coupled-simulation, coupling, fluent, fluent-ansys, fluent-mechanical, fluid-flow-fluent, system-coupling, transient-structural, two-way-coupling
December 19, 2025 at 7:28 am
andres.baeza
SubscriberHello everyone. I was watching an FSI video (
) in Ansys, where they connected the "solution" cell of the transient structural model to the "results" cell of the fluid model to display fluid and structural results simultaneously (at 2:31). However, I can't make this connection when I run my own FSI simulation example.1) Why can't I make this connection in my FSI simulations, and how can I fix it?
2) How can I display fluid and structural results simultaneously?
Thanks in advance for your answers.
January 2, 2026 at 1:33 pm
Anilkumar
Ansys EmployeeHi,
I hope you have installed the CFD post on your machine. The Fluent simulation components Results tab needs CFD post installation so that you can open those Fluent and Mechanical results within CFD post for postprocessing. Please do this step once your system coupling simulation is complete or solution steps are upto date in the individual Transient Structural and Fluent.
In other way, you might see Ensight files also written by your system coupling simulation which will also allow you to visualize results for both Mechanical and Fluent simulation.
Thanks,
Anil
January 2, 2026 at 3:53 pm
Rahul
Ansys EmployeeStarting Ansys 2021 R1, CFD-Post does not support reading Transient Mechanical 2021 R1 or later results files. You should take your FSI results to EnSight for simultaneous post-processing of participants.
Postprocessing Coupling Results in EnSight-
January 20, 2026 at 10:12 pm
andres.baeza
SubscriberAre there any other links about "Postprocessing Coupling Results in EnSight"? I can't access that link because I don't know my university Account Number (Customer Number).
January 21, 2026 at 3:08 am
Anilkumar
Ansys EmployeeHi
Can you please check this location? I hope you have access to below links.
Anil
January 22, 2026 at 6:57 am
andres.baeza
SubscriberI have access to both links, thank you very much!!!I'm not sure if I could create an animation in EnSight showing how the fluid deforms the structure and vice versa. I haven't been able to do it in my first attempts. For now, using the System Coupling files, I can only see the results in the interfaces.Is it possible to create an animation in Ensight showing how the fluid deforms the structure and vice versa (that is, showing both)?
January 22, 2026 at 12:57 pm
Rahul
Ansys EmployeeAfter the data under .../SC/Results was loaded into EnSight, only the FSI mapped results are imported. You can load the participant results to Ansys Ensight. For example, if you have the FSI results (Fluent-Mechanical Coupling), both Fluent and Mechanical results can be loaded in Ansys Ensight along with System Coupling results on interfaces. And then you can create an animation in EnSight showing how the fluid deforms the structure and vice versa
January 22, 2026 at 1:03 pm
January 23, 2026 at 4:10 am
andres.baeza
SubscriberThank you for your responses.I was trying to add the Fluent case without System Coupling in EnSight, and when I opened the ".encas" file in EnSight, I had no problems (in Fluent, I used Export -> Solution Data and selected "EnSight Case Gold" as the File Type).However, after creating another Workbench and running System Coupling between Fluent and Transient Structural, when I tried to open only the Fluent ".encas" case in EnSight, I got the error "Unable to set data format." I don't know if it was a coincidence that one worked and the other didn't, or if it's related to simulating with System Coupling and then trying to open the ".encas" file associated with Fluent in EnSight.What could be the causes, solutions, and/or recommendations so that I can open the Fluent-associated case in EnSight after running the FSI simulation with System Coupling?
January 23, 2026 at 4:22 am
Anilkumar
Ansys EmployeeHi,
I think your are giving wrong inputs.
Can you please give the correct file path for encas? in the image it is showing dat file and that is why you are getting this error. you can go to advanced interface and choose the format to be Ensight Gold and give the correct file path then you should be able to import the file.
Anil
January 24, 2026 at 1:08 am
andres.baeza
SubscriberThank you so much for your answers.I created a second example where I fixed the previous problem, but I encountered another error:How do I find the "Console" window? What could be causing this error, and how can I fix it?Is it possible for someone to make a video demonstrating an example using Ensight with system coupling (also including Fluent and Mechanical cases)? (optional)
