TAGGED: #Twinbuilder, ansysmotion, digital-twin, mechanical
March 25, 2026 at 10:30 am
marvin.frisch
SubscriberHello, I want to setup a co-simulation of a feed axis of a machine tool. For this, I need a system representation of the control system (P-PI-PI cascaded loop), a simple motor representation, the mechanical motion (a turning motor, spindle and a moving table) and ideally some mild FEM to simulate deformation in the spindle. I'm specifically interested in non-linear dynamics introduced by both the control system and friction within the system, so any coupling methods that imply linearity are out. Goals of the simulation would include a modal analysis of the whole coupled system (including the control) to gauge the impact of different design parameters (stiffnesses in the axis, control parameters,...) and some vibration analysis in motion. Ideally, the simulation could be run from the command line on an HPC. I do not want to investigate thermal influences or electrodynamic losses. I'm quite new to Ansys and am now wondering what the best practice for setting up such a system would be and feeling a bit lost in between Twin Builder, System Coupling and Workbench. If anyone could share some tips or experience, I would greatly appreciate it!
March 30, 2026 at 7:06 am
Ashish Khemka
Forum ModeratorHi Marvin,
I do not have an idea on Twin builder but please see if following links help you:
https://www.ansys.com/en-in/products/digital-twin/ansys-twin-builder#:~:text=Build%2C%20Validate%2C%20Deploy%20and%20Scale,and%20retain%20a%20competitive%20advantage.
https://www.ansys.com/blog/boost-simulations-with-roms-digital-twins#:~:text=Twin%20Builder%20couples%20with%20Ansys,and%20electric%20machines%20and%20actuators.
Ashish Khemka
6535
1311
