December 1, 2022 at 6:33 am
tamer elsayed
Subscriberi am simulating a friction stir spot welding process which includes a large deformation and modification of the contact and mesh shapeÂ
i am applying a rotational speed on the cylindrical tool, after trying all ways, the tool didn't rotate, which lead to incorrect simulation, and accordingly, Â reduce the frictional heating and reduce of the volume loss due to weari feel that there is some conflict between the element or contact type that i used with the rotation command, but after my extensive study, i know that the element type and contact type used are mandatory to perform the process
also, i tried using cylindrical joint instead of rotational velocity, or remote displacement with y rotation, but also not workingÂany help to let the tool rotate
December 9, 2022 at 4:58 pm
John Doyle
Ansys EmployeePerhaps you could try this in 2D and apply rotational velocity is similar way as demonstrated in Chapter 43 of the R2022-R2 WB Showcase Example Problem. Use many time increments and sufficently fine mesh.
- The topic ‘Friction spot welding’ is closed to new replies.
5824
