March 8, 2024 at 8:39 amzy JSubscriber
How to simulate the dissolution of sulfur dioxide in gas into water? Gas-liquid mass transfer in Fluent seems to be possible only from liquid to gas.
March 8, 2024 at 9:42 amRobForum Moderator
No, that's fine. You just need to order the from-to phases as per the documentation. Mass transfer works in both directions, with a negative value for mass transfer coefficient when it's going the "other" way.Â
- The topic ‘Fluent interphase mass transfer’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Cyclone (Stairmand) simulation using RSM
- error udf
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Encountering Error in Heterogeneous Surface Reaction
513
488
225
209
