March 9, 2023 at 6:56 am
Sahil
SubscriberHello,
I am trying to use the watertight workflow to mesh a geometry. I was able to mesh a bigger version of the same geometry perfectly fine. When I reduce the geometry height and try the same, it gives me the following error while applying share topology.
Error at Node 0: tg-update-objects-in-zones: wta[1](string) [0]
I am unsure how to proceed. Any help is really appreciated.
Thank you.
March 9, 2023 at 12:10 pm
Nikhil N
SubscriberHello, can you share the screenshots of the geometry as well as the error message from the console?
Nikhil
March 9, 2023 at 5:24 pm
March 10, 2023 at 5:50 am
SRP
Ansys EmployeeHi,
I suggest to please look at the tutorial for meshing:
Hope you find this useful.
Thank you
March 10, 2023 at 4:46 pm
Sahil
SubscriberHi,
I followed this tutorial. It worked for the bigger geometry but did not work for this one.
I have tried multiple times. I do not think the steps before sharing topology have any impact. If I share the topology in SpaceClaim, it works perfectly. However, in my case, I need a non-conformal mesh, and sharing topology in SpaceClaim removes that option.
Thanks again for your suggestions.
- The topic ‘Fluent Error at Node 0: tg-update-objects-in-zones: wta[1](string) [0]’ is closed to new replies.
