3D Design
3D Design
File converter error
    • Roberto
      Hello
      I want to convert files from scdoc to the new SpaceClaim format.
      When I select an entire folder in the converter with the following options (I've attached an example photo), it causes problems.
      For example, the folder is located in C: and I want to export all the files to a folder on the desktop I created called converted files.
      The converter starts creating various folders and subfolders, but it randomly places the files in and out. It doesn't maintain my file structure and even creates duplicate files.
      Regards
    • Devendra Badgujar
      Hello Roberto,
      This is with the latest version of SpaceClaim right?
      Devendra
    • Roberto
      Hi Devendra
      If this is the latest version of SpaceClaim, do you have a solution? Are you aware of any similar issues?
