Electronics
Electronics
Error in Dee Electrode Cyclotron
    • Megumi Sano
      Hi, I'm beginner.
      I'm simulating electric field of Dee electrode in cyclotron with Ansys Ekectornics Destop Student 2023 R2. In this step, I don't mind frequency.
      Before adding insulator, I succeed to analyze and visualize electric field. However, after adding insulator, analyze error  popped up that "Error in SAT file: not enough data. Simulation completed with execution error on surver. Local Machine."
      I can't understand what the error is. It seems some conditions are not sufficient.
      As the image shows, I put Ground(steel), Dee electrode, vaccum area(vaccum), insulator(polyether).
      Excitation: Ground(bottom-surface) 0 V, Dee electrode(top-surface) 50 V, vaccum area(top and side-surface) 0V
      Boundary: insulator insulation
      Please give advice to me.
    • GLUO
      Is the insulator an imported model? If yes, could you replace your insulator model with a simple cylinder and see if the error persists?
      GL
  • The topic ‘Error in Dee Electrode Cyclotron’ is closed to new replies.
