Error: eval: unbound variable when executing command
    • Mathieu G
      I'm trying to change a BC during my calculation using the "Execute Command" function. I'm executing :
      (if( < 0 (pick-a-real"/report/v-i/max 8 9, pressure n")) (ti-menu-load-string"/define/b-c/z-t 13 interior"))
      It's working fine when tested in the TUI but during the actual calculation I'm seeing this error :
      Error Object: 0
      Any idea why it's not working in the execute command promt ?
      Thanks
      Execute commands trigger every some iterations or once at a set iteration number (or timestep/time) so can you check if it's triggered once and then given an error or failed on the first attempt. I've never tried changing a boundary in this way, it's always been via UDF.
      • Mathieu G
        I copy/paste the same command from a previous model and it worked. My guess is that the issue was coming from the quotation marks
      Possibly, Scheme is very particular about syntax, order, what colour your socks are etc.
  • The topic ‘Error: eval: unbound variable when executing command’ is closed to new replies.
