LS Dyna
LS Dyna
Error about SPH neighborhood
    • lsdyna928
      I encountered the following error while running my simulation on an HPC  using LS-DYNA R12:
      *** Error 41434 (SOL+1434)
      Error encountered in SPH neighborhood search routine.
      Please check mes#### file for detailed information.
      Based on another Q&A on this forum, I increased NMNEIGH in *CONTROL_SPH and ran the simulation again. However, the simulation terminated with the same error. In fact, the error occurred even earlier than before.First run: error occurred at 1.7 s of simulation time. Second run (after increasing NMNEIGH): error occurred at 1.2 s of simulation time. I am using LS-DYNA R12.
      Could someone please help me understand: What is the most common cause of this error?
      What is the solution?
      Is there a way to prevent the simulation from terminating when this error occurs, or is the termination unavoidable?
      Any suggestions would be greatly appreciated.
    • Nanda
      Hello user,
      Could you test any latest solver? R16.1 or R17?
      Nanda.
      Have a look at our public help documentation website: Ansys Help
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
      • lsdyna928
        The only version installed is 12.2.1
        Is that the only solution for this error?
      • ramanb
        Could you please check how the particles are being created?
        It appears that they may be generated non-uniformly. If that is the case, could you please recreate them using a uniform distribution and verify the results?
        Please create these particles using LS-PrePost.
        Please let me know your findings.
        Raman Babu
    • Nanda
      I can't guarantee that it will resolve. But the SPH code has undergone significant improvements from R12. It could help.
      Nanda
    • ramanb
      Raman Babu
