3D Design
3D Design
Enclosed surface
    • TZakova
      I have a solid that I would like to create a surface from. I detached the surfaces of that solid and then merged the surfaces together. The problem is when I merge all the surfaces together in Spaceclaim it automatically generates a solid. How can I create an enclosed surface without it becoming a solid? Bellow is a screenshot of my cuboid.
      Thanks in advance,
      Tereza
    • Devendra Badgujar
      If the surfaces form a close cube merging them would create a solid out of the surface. It is intended.
      You can delete any one surface and then try combining it will result in one single surface.
      Devendra
    • TZakova
      Dear Devendra,
      Indeed that is possible to delete a surface - however then it is not an enclosed surface. Otherwise I will always have minimum two surfaces. Is there a ways to make that into one? Thanks in advance.
