August 6, 2025 at 4:27 pm
evan
SubscriberHello,
The recently released Ansys Electronic Student 2025 and its corresponding file, ELECTRONICSSTUDENT_2025R2_WINX64, have a bug. It fails to install preqrequisites MS ASP.NET Hosting Bundle 8.0.17 and MS VC++ 2022 Redistributable x64 when installing. Once I manually installed those two programs, the installer and the ProductConfig failed to recognize the VC++ x64 program (it did recognize ASP.NET though).
Nothing I tried changed this (I tried a lot). I ended up reverting to Ansys Electronic Student 2024 with file name ELECTRONICSSTUDENT_2024R2_WINX64, which allowed the installation to work on the first try.Â
August 11, 2025 at 10:28 pm
Hamad-eqkn
SubscriberHi Evan, I’m facing exactly the same issue you described with Ansys Electronics Student 2025R2. If possible, could you please share the 2024R2 Student version installer with me? Thanks in advance. -
August 13, 2025 at 4:26 am
ramustudywork
SubscriberSame problem, python crashÂ
August 14, 2025 at 5:55 pm
randyk
Forum ModeratorHi evan,
I will reach to you directly to troubleshoot - providing the resolution to this thread.
Thanks
Randy
5879
1306
