January 25, 2024 at 4:44 pmChristopher CurrySubscriber
I am importing a mesh (.stl) file from COMSOL into ANSYS. Is there any way to be able to edit the geometry of the .stl file, add a geometry over it, or convert it to a 3D CAD file type in ANSYS (as the only file I can import is .stl due to my previous model)? Additionally, can ANSYS be used to segment an MRI?
Thanks!
January 25, 2024 at 11:45 pmpeteroznewmanSubscriber
Start Ansys SpaceClaim then File, Open and set the file type to STL. Then you will have access to the faceted body. SpaceClaim has a lot of capabilitiy to edit STL data and convert it into geometry that can be meshed in Ansys Mechanical.
I have made several videos of the process of converting STL data into geometry for meshing. See the STL File Editing playlist on my YouTube channel.
No, Ansys cannot segement MRI image data, other software is used for that job. A free software package that does segment MRI image data is called Segment.
- The topic ‘Editing imported mesh file as geometry’ is closed to new replies.
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Frictional No separation contact
- Elastic limit load, Elastic-plastic limit load
1301
591
544
524
366
