Ansys Products
Ansys Products
Dependicies needed for CentOS 8.3 for ansys fluent and ansys mechnical (FSI)?
    • Julio Mendez
      Hi, I am trying to run FSI (2-way coupling) in Ansys workbench on a CentOS 8.36 system that runs on a container. When I run the tutorial of FSI on a windows workstation, it runs perfectly fine. Still, when I run the same workflow on a CentOS 8.3 system running on a container, I get the error: "Update failed for the solution component in System Coupling. The coupling service failed to start."
      Any Idea ?
    • George Karnos
      Please see Chapter 2 of the linux installation guide for all required libraries ad prerequisites.
    • Julio Mendez
      George, thank you very much indeed for your response. Is the guide publicly available? I only have access to the student version (windows).
    • George Karnos
      The installation guide is located on the ANSY Customer portal.
      Whoever downloaded and installed on the linux machine should be able to access it.
    • Julio Mendez
      I found one manual, but the version is 16.2, and the version we are testing is 19.2 :s
    • Julio Mendez
      Thanks George, I am helping a team from UTD to troubleshut their application, since I am an external consultant I do not have access to their software stack, license and support representatives. I'll see if they can share some extra documentation with me.
    • George Karnos
      19.2 was not tested or certified on CentOS 8.3
      Please see the following for Supported Operating Systems:
      https://www.ansys.com/it-solutions/platform-support
      https://www.ansys.com/it-solutions/platform-support/previous-releases
    • Julio Mendez
      George, thank you very much. I realzied that I can find the information you suggested even from the student version I have, from teh help menu. It is quite useful !! Unfortunately, the student version comesin windows only
Viewing 7 reply threads
  • The topic ‘Dependicies needed for CentOS 8.3 for ansys fluent and ansys mechnical (FSI)?’ is closed to new replies.
