July 25, 2024 at 4:59 pmEmiliano MaldonadoSubscriber
Hi everyone,
I'm carrying out a MSUP harmonic analysis with damping coefficients (introduced as "Ns/m" values in a ground-to-surface connection) and a damping ratio as well.
Is it possible to make both of the damping work on the MSUP harmonic analysis? As far as I have seen, the damping coefficientes are not participating in the analysis.
Thanks in advance!
July 25, 2024 at 9:51 pmAnkush ChoudharyAnsys Employee
We can use the element damping (Ns/m) in MSUP harmonic analysis. However, in modal analysis, you have to use a Reduced Damped solver.
July 26, 2024 at 6:58 amEmiliano MaldonadoSubscriber
Hi Ankush,
It worked out very well. Thank you very much indeed.
- The topic ‘Damping coefficients and MSUP harmonic analysis’ is closed to new replies.
Ansys Innovation Space
- How to apply Compression-only Support?
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Image to file in Mechanical is bugged and does not show text
- Element has excessive thickness change, distortion, is turning inside out
635
599
591
366
