CosimulationError Solver (2way FSI)
    • Farah
      I'm running a two-way FSI simulation (with blood and a group of vessels). I start ANSYS using Visual Studio, run SC, pause it, then go to Fluent to load my UDF, and continue the calculation. But I get an error message from SC and Fluent.
      I tested my UDF in CFD before, and it worked fine. Can you help me fix this issue? Thanks!
      SC:
      | Error when making a remote call to participant Solution 1.                  |
      Traceback (most recent call last):
        File "PyLib\cosimulation\remoteclient\__init__.py", line 98, in makeRemoteCall
        File "PyLib\kernel\remote\RemoteObjects.py", line 52, in func
        File "PyLib\ComputeNodeCommand.py", line 118, in newfunc
        File "PyLib\ComputeNodeCommand.py", line 85, in raiseException
      RuntimeError
      During handling of the above exception, another exception occurred:
        File "PyLib\cosimulation\solver\__init__.py", line 156, in solve
        File "PyLib\kernel\util\Memory.py", line 208, in wrapper
        File "PyLib\cosimulation\solver\__init__.py", line 697, in __stepControlled
        File "PyLib\cosimulation\solver\__init__.py", line 763, in __iterateControlled
        File "PyLib\cosimulation\participantmanager\couplingparticipant\NewApisParticipant.py", line 266, in getRegionsRequiringUpdate
        File "PyLib\cosimulation\remoteclient\__init__.py", line 103, in makeRemoteCall
      cosimulation.solver.CosimulationError.CosimulationError: Error when making a remote call to participant Solution 1.
      Fluent:
      Node 999999: Process 101552: Received signal SIGSEGV.
      =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
      =   RANK 0 PID 89872 RUNNING AT arc-research-07
      =   EXIT STATUS: -1 (ffffffff)
      ===============Message from the Cortex Process================================
      Fatal error in one of the compute processes.
    • Rahul
      Is it failing while restarting the solution?
      Which participants are being used in this coupling study?
