June 3, 2020 at 5:14 pm
Kshitika287
SubscriberDear sir/ma'am, I am Kshitika and I'm from a Formula Student Team. While simulating for composite materials on Ansys Acp I got a doubt. We don't use prepreg materials thus we generally add Epoxy carbon wet as fabric in our simulation. Now, if we used Carbon fiber(only fibers) as fabric and later add Resin Epoxy as a global drop-off material we should be getting the same results right? But after simulation in static structural we got entirely different results in both cases. Is there anything specific which we missed out on while adding the only fiber fabric? We think that in both cases results should be the same because just as the vacuum infusion technique there is fabric first and then the resin enters and in vacuum bagging we have fabric with resin which becomes the wet fabric case here and then it is cured.Â
I'd really be thankful for your help.
Regards, Kshitika.
June 23, 2021 at 9:07 am
David Mercier
Ansys EmployeeKshitika287 , Why not trying to use Granta EduPack or Granta Selector to estimate properties and performance of different composite materials before doing simulation. You could save some time in front of your simulation work. Such analytical approach is based on the estimation of properties using law of mixtures and you can compare results with reference data. Here a discussion about the tool used for that: /forum/discussion/28626/what-can-i-do-with-the-synthesizer-tool-in-granta-edupack#latest
Regards
- The topic ‘Composite Material choice in ACP’ is closed to new replies.
- Stopping simulation automatically at composite failure based on displacement
- QuartodiLitro Motostudent | Fork feet analysis and optimization
- E-Racing Bergamo | Chassi’s torsional deformation
- Tress structural´s simulation using carbon fiber tubes
- CFD Simulation (Fluent) on Brazil FSAE CAR (FORMULA UFPB)
- Mission to Launch: Precision Engineering at UPC Space Program with Ansys Simulat
- Transmission System Development (Structural Simulation) Protto UFSC Motorsport
5874
1306
